- Jul 27, 2003
- New York, New York
Is their a way to install and run photoshop in linux. I am in the process of installing gentoo with gnome as my GUI. Will i need wine or wineX and how will its performace be?
ObnoxiousFrog said:..., adobe products are hobbyist software in a professionally priced box... Ex. compare final cut pro to premiere, avid to either. With avid you get what you pay for... With open source you get what you deserve ...
hafa said:Hmmmm...Good luck getting a job in any pre-press oriented company. Adobe products are the world standard for pre-press layout. You can use open-source until you're blue in the face, but very few (if any) professional print shops will be able to handle them. FWIW, gimp is not a bad program for simple photo editing, but is a pale reflection of Photoshop's robust image editing capabilities at the professional level. Try doing a multi-channel joined mask with feathering in LAB with Gimp...
