- Mar 12, 2001
- Southern CA
After setting up phpBB, the server never got past creating phpBB tables, so the next day I tried again.. Evidently the tables are already there so I need to delete the DB and start again. Admins tell me to run php script or use phpMyAdmin (which I was going to install anyways) to delete the tables.
Testing DB Connection...DB Connection Good!
Selected database harrison...Database Selected!
Creating phpBB tables an inserting default data...
Creating table cat ERROR! Could not create table. Reason: Table 'catagories' already exists
SOOO I load up phpMyAdmin, and follow the directions, and now I get this:
Warning: Unable to access ./libraries/auth/.auth.lib.php in /home3/harrison/public_html/phpMyAdmin/libraries/common.lib.php on line 337
Warning: Failed opening './libraries/auth/.auth.lib.php' for inclusion (include_path='') in /home3/harrison/public_html/phpMyAdmin/libraries/common.lib.php on line 337
Fatal error: Call to undefined function: pma_auth_check() in /home3/harrison/public_html/phpMyAdmin/libraries/common.lib.php on line 338
This sucks when I don't know what's going on...At least with programming I can ask a fellow student.
Here nobody knows php!
