Picked up new RX 480 OC 4gb for $155
trents
trents
Senior Member
Boy is this thing faster than my RX7 360 OC! Heaven FPS went up from like 20 something (if memory serves me) to 109.6 on High Quality setting.
JLK03F150
What have I done! Member
Georgia
That's exciting to read. I've bought a 480 8gb from the classifieds. I can't wait to receive it! I'm running 3840x1024 resolution. The extra vRAM should be helpful to my setup.
trents
trents
Senior Member
The fans don't even turn until you put it under load and then they are still unusually quiet. Ran the Heaven benchmark and top GPU temp was 70c.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
ick. Scrap those 3 ancient Los res monitors and get a big one... 480 will struggle in some titles that res I'd imagine. It's a good 1080p card.. not much higher.
NewbieOneKenobi
Warsaw/Poland
You lucky Americans. :)
This said, Europe sees them falling too, just not nearly so much.
Between 8GB VRAM and a strong CPU the outlook might be a bit less bleak for fps till one got a proper 4K card, though? Just theorizing, no experience with anything larger than 1440p. Which I'm quite sure is already going to be taxing @ everything ultra on mainstream CPUs in newer games. Something like 6600K + 480 in 1440p @ ultra and MSAA 4 is not going to see 60 fps, probably not even close. But a stronger CPU and enough VRAM to process nice textures and high resolutions just might be able to squeeze out a couple of fps to make things tolerable by lifting that burden off of the GPU, perhaps also in somewhat higher resolutions on high instead of ultra, or something.
trents
trents
Senior Member
I'll PM you my shipping address so you can buy one for me.
