- Mar 1, 2001
- Sacramento, CA.
Got a hold of a snappy and a video camera, thought I'd post a couple pics of my system with the water cooling in it.
It came that way from Abit, I have heard, however, that that little fan is not that good so I will be replacing it with a Blue Orb. There are 2 mounting holes in either corner to mount fans with.Walter:-( (Apr 03, 2001 01:36 a.m.):
How did u attach that fan on the North bridge?
TT120 (Apr 03, 2001 07:25 a.m.):
I used the Snappy software. A Snappy is a parallel device for capturing video from a composite device like a camcorder or vcr.Executor (Apr 03, 2001 01:48 p.m.):
what program did you use to capture the pic´s from the camera?
Yeah, but if you cut the holes on the Blorb so that they are slots instead of holes and use washers it will work.burzmali (Apr 04, 2001 11:25 a.m.):
the blue orb won't fit on the kt7 / kt7a northbridge. the mounting hole are spaced wrong.
