- Aug 17, 2011
- Kailua-Kona, HI
epic pictures and build. temps? clocks?
What should I do with cooling tubes?
A: Mix of copper and clear plexi tubes?
B: Pure plexi tubes?
C: Pure Copper?
Personally i am leaning mostly towards A or C, but i am scared that going for a mix of copper and clear will stupid? Going all out copper with revive my long time dream of doing just that.
Thoughts?
How about an option D. Chromed copper? I've seen quite a few builds sporting chromed copper tubing and it looks great.
I just picked up a Enthoo Primo myself. I like it and it does mostly everything right but there's a few things that I feel are lacking a bit of polish. How much did phanteks charge you for that 2nd pwm controller?
If it was me I would prolly go full copper.
Good choice on going full copper. I think it will dissipate a little heat as well while the flow is going to the rads. I would possibly go full copper bling look or chrome. Depends what everything else is, including the fittings.
As for the waterblock on these motherboards, I am not really sure but do recall hearing that some time ASUS MBs, from the older models that had aluminum made blocks but could be wrong. Maybe they changed them or what not. I'll look around if I get a chance and see. What MB is this again?
C: Pure Copper?
Thoughts?
gaming on the 27th... watch_dogs!!!
I actually wish I could sleep until the release date so I don't need to deal with waiting. I'm almost worried my expectations may be a little too high.
