PII 266Mhz - possible to overclock?
hckymeyer
MN
My girlfriend has a PII - 266Mhz CPU in an old dell computer. She has 192MB of EDO Ram. (I think that the right name....anyways it's the really old stuff, no SDRAM) It has the stock HSF and I was wondering if it would be safe heat wise to overclock this. I can change the FSB from 66 to 100. The case is not a tower...it's one of the flat desktop ones.
JDXNC
Have you tried setting it to 100 FSB? It *might* work, but I think thats a pretty big jump... won't hurt to try. Might be just as easy to pick up a used PII 400 or 450.
OCed_5150
Somewhere in Time...
Sure as hell can.
Try this link first and choose the Intel CPU Pentium II 266.
http://www.cpudatabase.com/CPUdb/
Might need a good overclocking board that's all. But SLOT 1 boards are getting very rare. Im sure there are some used ones still around like the Abit BH6 / BX6. Use PC 133 SDRAM and a Large Slot 1 type Heatsink. Just have to be careful of the low PCI dividers.
batboy
Senior Moment
Kansas, USA
!00 FSB is probably asking too much. Those L2 cache of the P-II hampered overclocking a little, plus you only have stock cooling, but what do you have to lose? I ran a P-II 233 at 300 MHz for a long time. Try changing the multiplier, you might get lucky. Some of the early P-II CPUs still had unlocked multipliers.
Mr. $T$
batboy said:
Gotta love this quote by Tom.
"the overclocking scene will mostly be dead by Fall 1999"
ha :rolleyes: WOW he is a stinking genius, overclocking will be around as long as a processor still has a clockcycle. . . . ;)
quegyboe
BC Canada
There is a very good chance that those CPU's are unlocked, which means that if you can, you could just up the multi and get more speed!
