Xaeryan said:To overclock that processor + board combination, press Delete while booting to get into the BIOS... You will end up in the Main Menu of the BIOS. Now navigate to the "Advanced" menu. There are a few fields you will need to modify:
1. CPU Internal Frequency <- Set this to manual, we'll manage it ourselves.
2. CPU Frequency Multiple <- starting somewhere around the Pentium II, Intel locked these, so you can't change this.
3. FSB:SDRAMCI Freq. Ratio <- this should read 133:133:33 or 133:100:33 depending on your type of RAM (PC 133 vs. PC 100)
4. FSB/SDRAM/PCI Freq. (MHz) <- this is the biggie. This guy adjusts the frontside bus as well as memory and PCI bus speeds. You'll want to up these only a little bit (2-3 MHz) at a time, then make sure your processor runs stable at the new speed. If it runs stable fine. If not, it may help to increase the voltage slightly (see below)
5.) CPU VCore <- this controls the voltage given to your processor. when overclocking, it often helps to up the voltage a bit for increased stability. Never go crazy here, though, as this is where you can kill your CPU (although I've had it cranked and had no problems - I think the problem arises when you don't have adequate cooling). For starters, only bump it up .05 V at a time when you encounter instability.
OK, now I have some questions for you... check your BIOS. What is the CPU VCore when you first look (before you change anything)? Or even better, what is the model of your 1.0 GHz? SL4mF? SL52R?
Also, I see that you have 288 megs of RAM? Is that in 256 and 32 MB sticks? If so, I'd advise you to remove the 32MB. The extra memory is too insignificant, and it simply puts a strain on the CUSL2s (already finicky) memory controller. Also, we may be able to adjust your RAM timings to increase your speed. What kind of RAM are you using?
Also, you didn't mention your cooling... what heatsink/fan are you using? Stock? If you plan on overclocking, I'd advise a high performance cooler (see my signature for a great one).
Finally, what BIOS revision do you have? (If you don't know, it should be displayed almost immediately after you turn the computer on. Look carefully (and quickly)).
I'll try and help you as best as I can.
I think I lost you there... the CUSL2 uses an Intel chipsetcyberbod said:mobo is using the via chip set
Are you sure it's a CUSL2 and Pentium III ? Because Thunderbird is an AMD CPU... I'm not quite sure where you read Thunderbird.On buttom of cpu says Thunderbird cpu on start says pIII 1000eb not sure
That's simply because the multiplier cannot be changed on an Intel CPU (and if it turns out you're using an AMD processor and some motherboard besides the CUSL2, AMD's require a little trick before unlocking their multipliers.)and i can't get to the multipy option its greyed out on bios
Xaeryan said:BadThad: I do have to disagree with that... I have a SL4MF (cC0 stepping) that does 1162 stable. I have two SL52Rs (cD0 stepping) that will both do 1200 MHz stable. With my RAM set to CAS 3, they'll do 1250 (well, at least the one I'm using right now) - but it's faster @ 1200 with CAS 2 settings. That may not sound like alot, but remember, that's a 25% overclock!
Xaeryan said:BadThad: the one I'm running does 1200 at 1.90 (max available is 2.1), the other one requires 2.0. This one actually seemed to run fine at 1.85, but a few crashes that I couldn't determince the cause of led me to up the voltage as a "just-in-case" measure.
cyberbod said:
I just wanted to know if i have too over clock manualy or do it by bios i it should be the intel chip set i believe i just need a mod setting for bios setup if i can from someone who ever reads this..
reply... i seem can't to over clock the sucker...
