Pipe case Idea
EBFoxbat
EB, MA
How about this. I know pipes will block overall air flow, but I do have a full tower and not alot to produce heat. Maybe a dedicated vacume pipe for my gpu or just a pig one for my row-o-pci-slots. Then I could make one for my RAM.. I smell perhaps (not burnt cpu's) the birth of a pipe machine... any thoughts on putting tons of cooling and heat removal pipes in? I think I like the idea. Taking care of each heat source with its own heat-removal vacume pipe. What do you think?
CraxySerge
Niagara Region, Eh!
I think you should try your idea, which is interesting! Then share your experiances with us. Personally I dont know anything about thermodynamics, or anything close to that.
brothernod
I guess it could work, though air cooling has only a certain amount it can do.
what would be the big difference between having a normal exhaust and just ducting an intake the the hot spot??
you need to have the same intake and exhaust in your case, don't forget that.
