I have a 10-year-old Delta 120mm fan than came out of a server. Work fine and is very quiet (yes, Delta *can* make a quiet fan!) Problem is I have no place to install it. Because of case design (smallish mid-tower) it just won't fit in either the front or back panels.
So I'm thinking, what about the bottom, facing up, blowing in? Lots of room there. I would also add some custom feet to raise the case up maybe another 1" or 1-1/2". What do you think?
