- Sep 3, 2002
Hey guys.
I am just gonna write down my planned O/C setup. I will scan in some pictures and post some digital pics when I get a chance, which should be soon. But for now, just consider the following:
Components:
Danger Den Radeon 9700 W/C Block
CPU Block: Maze3 or TC-4 (most likely TC-4)
Heater Core from a 89'ish Camaro (from Natedogg)
Blue water dye
Some kind of water thinner (Velocity T3?)
Water Pump - Via-Aqua 370GPH Pump
Bay-Res Resivoir
9 ft 1/2' tubing
Custom Made, Custom Soddered (Aluminum or Copper Sheet Metal) shroud with 120mm 100CFM+ fan
Shroud for the other side, without a fan.
This is the intended setup:
Pump->Heater Core->CPU Block->GPU Block->Resivoir->Pump
My case is a mid-tower I am working with limited space. I have "blueprints" for the heater core + fan + shrouds drawn. I'll take pictures of the case and whatnot for future reference.
Components:
Blue water dye
Bay-Res Resivoir
9 ft 1/2' tubing
