Planned WCing System; Comments?
JoT
You can't fire me, I have
After thinking a while and planning a while more, I have chosen the components to go into my system.
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=16
I chose this because I noticed that the same rad is in the scratch and dent section for half price. I'm not sure on how it performs, but it doesn't look too horrible. Should I get this or a different one, or go through the trouble of trying to get a chevette heater core? (I hear a lot about those things)
White Water waterblock
I know it's #2 only to the Cascade, and half the price.
Eheim 1250 Pump
Also buying from D-Tek, $70 seems to be a good price for this pump, unless someone has a better place. I would rather get an Iwaki, but it's just too expensive.
I need some recommendations on what north bridge and VGA blocks to get. (I have a 9700 AIW)
Using a T-Line, some tygon tubing, and a blower on the rad. All 1/2" connections.
Thanks for your time, guys.
the dtek procore is a chevette heater core, except it has fittings already on it and is painted. you could save about 15 bucks and do it on your own.. anywho, it a top preformer for the size.
everything else looks pretty good too. you could go with the dtek NB and VGA block, it may be a bit more expensive then some other blocks, but you'll save shipping since you're already ordering a few things from dtek anyways.
