- Sep 15, 2007
- Small town Emlenton, PA
Well, I guess you could. Startup amps on those fans is over twice the nominal amps. So I wouldn't.
Two 35x pumps in series is what you need.
Today is June 4th.
Haswell has arrived. The new generation of nVidia graphics cards are available too.
I have begun the process of ordering the parts for my new build. I am not an artist, so this won't be a show piece. It should be a highly functional system though.
The basics of the computer are:
CPU: i7-4770K
MB: ASUS Z87-PRO LGA
RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB)
Corsair 900D
SeaSonic X-1250 80 PLUS GOLD
The water cooling components:
Swiftech MCP35X 12v PWM Controlled Water Pump
- Optional Tank Res
- MCP35X-HS Pump Heatsink
- Yate Loon 80mm x 25mm Fan
Coolgate Quad 120mm Ultimate Heat Exchanger Radiator (CG480) x 2
Koolance CPU-380I Intel Liquid Cooling CPU Block
PrimoChill PrimoFlex Advanced LRT Tubing 1/2"ID x 3/4" OD - Clear
Koolance Coolant Temperature Sensor Plug x 2
Bitspower Matte Black Sealing Plug For ID 1/2" Tube x 2
IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip x 2
1/2" ID UV Reactive Leakproof T Fitting x 2
Phobya Reusable 3/4" OD Hose Clamp - Black x 22
Gentle Typhoon fans AP-45 (in pull) x 8
Sunbeam PL-RS-6 Rheosmart 6 Fan Controller 5.25" Bay 6 Channel 30W Fan Controller Panel
After reading 3 Step Guide to Overclock Your i7 / i5 Haswell Platform
by hokiealumnus
http://www.overclockers.com/3step-guide-to-overclock-intel-haswell
I hope that two 480 radiators will be sufficient to cool the two 780s and the 4770K.
2) Is it prudent to have two temperature sensors, a flow sensors, and a pressure sensor in the system?
Thanks in advance for constructive criticism and advice.
I planned to control the pump by plugging it into the motherboard. I wanted the fan controller with at least 30W per channel for the 12 or 13 fans I will be using. I'm using the Gentle Typhoon AP-45 which has a 0.53A starting current; so I can put 4 fans on a channel.awesomehandle31
Incase you didnt know... you will not be able to control your pump from that fan controller... but you can control it form this one. http://www.frozencpu.com/products/11...?tl=g47c17s240
The sensors are sort of "play". After all this is a hobby. The cost of the liquid cooling system around $700 (actually this does not include the extra cost of the two EVGA water cooled 780s which would bring the total to about $1000) can not really be justified by the quieter system and possibly higher overclock.Conumdrum
Sensors are silly. Many new folks get them and play with them. After a while, on the next rebuild folks realize they do nothing but have too many wires and restrict flow.
Let the new guy play.
The sensors won't restrict flow. The flow meter does a bit. Every extra fitting etc reduces flow. In your situation you'll be fine etc. Just have fun is all that matters.
Ohh so you dumped the flow and pressure meter? Good.
Thanks for the advice.
I think a little physical effort now may save a lot of trouble later. So I'll do a few more "fill, shake & drain" and see if any more debris comes out.
I am going to take the time to do this right.
All my parts are not here yet.
Just exploring the Corsair 900D case is going to take an expedition.
