I'm currently planning on adding a custom water loop into my system in the near future. The reason being is the I like to run SLI cards and the temperatures are too high for my liking during long sessions of gaming.
My current setup is as follows:
CM HAF 932
Asus Sabertooth x58
Core i7 920
Noctua NH-D14
MSI GTX 570 Twin Frozr II
I believe this will be all that will be run under water (eventually, and so-to-speak). Currently I have one 570 right now (a side-grade move from dual 460's because temps were unacceptable to me). I will be adding another 570 later on. Right now I am using FrozenCPU's website to get an idea of the cost of parts and will be linking to that site exclusively. This is not to say that I am dead-set on ordering from them; they just happen to have a large variety of items/manufacturers and its easy for me to dump everything into a cart and ball-park the costs.
One question I have is concerning quick disconnects. Outside of ease of use (quickly separating parts of the loop, less leakage, etc.), what are the benefits to them and can the cost be justified? For each end of a hose I would want this installed on it will run 27.98$ total (1 Male and 1 Female connections). Also, exactly how many of these things will I need for a full single GPU loop and an SLI GPU loop?
Another big question I have is concerning pressure inside the case and how this will affect the loop. As it stands now, here is my fan setup:
1x 200mm front intake fan
1x 200mm top exhaust fan
1x 140mm rear exhaust fan
1x 120mm bottom intake fan
2x 120mm side intake fans
2x 120mm side exhaust fans
The four side fans are arranged in a 2x2 block with the bottom two being intake and the top two being exhaust. The bottom two blow almost directly onto the video card.
Obviously I will be getting rid of the top exhaust fan in place of a radiator. As far as fans go with the radiator, is there a major improvement with a push/pull fan setup (fans on both sides of the radiator) versus a single row of fans? Also, in a single row scenario, which is more beneficial: to have the fans push the air through the radiator or pull the air through the radiator (fans on top or fans on bottom).
Barring the top fan, which fans would I want to keep and which would I want to get rid of. All of the 120mm fans are Scythe Kaze slim fans. The others are the stock CM HAF 932 fans.
Ok. So on to the actual products I'm considering.
Setup 1:
XSPC Dual 5.25 Bay Dual Pump/Reservoir 255.93$ including 2x Swiftech MCP355 pumps and Koolance compression fittings.
Coolgate 3x120 Radiator 104.98$ including Koolance compression fittings.
Danger Den GPU full cover waterblock 145.94$ including Koolance compression fittings.
Danger Den 1/2" ID 5/8" OD tubing 29.95$ for 3 meters with cutters and clamps.
Total: 536.77$
Setup 2:
XSPC Dual 5.25 Bay Pump/Reservior 172.94$ including Koolance compression fittings.
Black Ice GT Stealth Radiator 82.94$ including Koolance compression fittings.
Total: 431.77$
In either setup, the Pump/Res will fill some bay slots and the radiator will be going in the top of the case.
Initially, I will only be cooling the one GPU. Over time and when I add the other GPU, I will also add it to the loop. I'm fairly certain that either setup will be able to handle dual GTX 570's in SLI. Eventually, I will also water cool the CPU. However, it will be in it's own loop. Adding another 2x120 radiator for the CPU in Setup 1 would not be that big of a deal as there is a separate pump/res for the CPU. In Setup 2, it could get tricky. I've also read a little about the Corsair H100 and don't think it would be difficult to add that in addition to Setup 2 for the CPU.
How viable would these builds be and did I leave out any parts?
Once again, I'm not set on ordering everything from FrozenCPU. It was just easier for me to find all of the parts I was looking for and throw them into a single shopping cart/wish list. I know that there are better deals on several of the parts and I will shop around quite a bit when I get closer to making a purchase.
Thanks in advance for any help/advice.
-BlakAcid
CM HAF 932
Asus Sabertooth x58
Core i7 920
Noctua NH-D14
Setup 1:
Total: 536.77$
Setup 2:
Total: 431.77$
-BlakAcid
