Windows 8 OS takes around 20GB, that is 100GB for your apps. Since you dont plan to play games, 100GB is really large compared to your needs. Your pictures, music, movies, etc... go to the HDD.
OEM means it is intended for manufacturer: you can pick the licence but it is available only for one PC with no major upgrade allowed.
For example:
You install an OEM version of windows on your PC which has an i3, 8GB of specific RAM, and an ASUS B85M motherboard.
Everything will work fine.
If you plan to change one of those components (CPU, RAM, motherboard), then your license is dead.
If you go OEM, it is for one rig only. You have to buy a new one if you change major parts of your PC.
Non OEM version are available for one PC only too but allows you to change parts, your license would still be good.
Personally I've never had a problem switching OEM versions with upgrade or even a rebuild, other than occasionally having to do phone reactivation which is a minor PITA, as long as you are just running it on one PC.Windows 8.0-8.1 is transferable using OEM os, just keep the receipt.
ok so here is what i have settled on so far
CPU: Intel Core i3-4330
CPU Cooler: Cooler Master Hyper 212 EVO
Motherboard: Asus B85M-E/CSM
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600
Storage: Crucial M500 120GB 2.5" Solid State Disk
Case: Cooler Master N200
Power Supply: Corsair CX430
Operating System: Microsoft Windows 8.1 64 bit
I know I dont need a cooler but for $30 and the good stuff i read about it i think it is well worth it.
