So I have been itching to build a custom loop and I'm in a spot financially right now where I can start to plan it out over the next month or so. I will be cooling an i7 9700k and a gtx 1080ti. I will be building in the Fractal Design Define S2. I have my eye on the EK Velocity Strike rgb Black Nickel+Black Water block, but have also been looking at the cheaper Velocity rgb Nickel + Acetal because I'm not sure how long I will be on this platform. I've been looking at alpha cool but besides those two places my field of focus is quite narrow. I plan to have a 30-45 mm thick 360 on top and possibly a 60mm thick 240 in front. Why you ask? BECAUSE!! Now my knowledge is faint as it pertains to tubing and fittings. I will be starting with soft tubing and don't really know where to start. I really like the look of thicker tube when soft. Maybe white, or like a deep gray or black. I have seen and will provide an idea of what i'm looking for. I just have zero idea the diameter of this tubing the type and size of fittings i need or where to find it. Of course I will keep looking but would love it if anyone can chime in and help. Also there is one more thing, I have the evga gtx 1080ti sc2 hybrid and need to find a waterblock for that as well. If I understand correctly it is nit quite a ref pcb. It appears ek does nit make a block for this card. Any links for gpu/cpu blocks would be helpful. I will probably use a pump res combo. Suggestions on that and links woud e awesome. Any cool stuff and ideas I will appreciate. I would like to be opened up to more companies and hardware that I'm not aware of. I am sure this site gets this ALL the time. And I will explore the past threads just haven't really had a chance yet. We are just now slowing down to the point I will be working only 40 hours a week again. Also since next Monday is my bday I have 4 days off and would like to sit down and compile a list of everything I am goin to get and need and get this process started. My h110i gt is fading, it's not holding up too well. If I absolutely can not find a block for this gpu then maybe I will get the Fractal Design Celsius 360 cpu cooler for now or build around it but I really want to make it work and go full custom. I am not entirely opposed to going rigid and just using a bunch of 90 degree fittings for now and making a loop with no bends to start with then maybe trying to bend and create something else while I'm able to use mine at the same time. Anyway thank you for reading and thanks for the help.
I really like the white but I know I've seen wrapped tubing in like gun metal or gray. Anything will help. I should be able to start ordering next month and have it ready to build in early December. There are a few more things I need to get. A 2tb m.2 for one.
Sorry that first pic is the wrong pic thats clear tube here is another one. It's a little thinner but I like the thick tube.
I am pretty dead set on getting this pump res combo from singularity computers at the moment unless anyone can suggest something else.
https://www.singularitycomputers.com/shop/watercooling/protium-150-d5-reservoir-combo-acetal/
