- Mar 7, 2008
Ring cache that is.
System is 6700k based. I'm aiming to optimise Prime95-like performance and don't care about anything else. This can be broken down into two test conditions: those workloads that fit inside L3 cache, and those that don't. In the latter case, ram is usually limiting. Putting that aside, the L3 cache isn't unlimited either. So I'm wondering if OC'ing that might help. Typically I leave it on auto, which on the mobo I use is 4 GHz. To my understanding, the L3 cache = ring cache.
I've done a slight core overclock so far, with 4.2GHz 1.25V seeming ok. Actually better than stock, as the system does 4.0 GHz at 1.33V+ for some stupid reason.
Next I tried jumping to 4.3 GHz for both core and ring. Booted ok, locked up on P95 stress. Not good. Put ring back to auto (4 GHz) and it has been fine for a while. I'm typing this over lunch, so will go back and play some more after that.
Is there any info on OC'ing the ring? A lot of info out there is gaming biased so useless. One place suggested 42x was easy but you have to pile on the volts to go above that, which is not inconsistent with what I've seen so far.
Thought does occur, I could test it backwards... if I lower the ring clock, do I see a drop in performance? If not, then I'm unlikely to see a gain from raising it.
