- Jun 7, 2001
I'm having difficulty finding a GOOD cooling system my Katmai, Slot1. Here's the only decent one I could find, Comments & Advice would be appreicated!
Application INTEL PIII SECC2 by AddA
Dimensions 105x47x20
Fan Size 2x(50x50x10 mm)
Rated Voltage (V) 12 volt
Noise Level(dBA) 18 dBA
Air Volume (CFM) 2x13CFM
Rated Speed(RPM) 5800 RPM
Bearing System HIGH SPEED-BALL BEARING
Heat Sink Aluminum 6030
Fan Safety UL/CE/CSA
Thermal Resistance Theta ja=0.85c/w
Connector Type 3 Pin Connector
