Log in as root and type
startx *1* . Then it is likely that one of three things happen:
1) You get a desktop screen - your graphics card works fine, just a bit of fine tuning to make it boot into the GUI
2) A load of text scrolls by, the screen may flicker and you get a few error messages. If this happens, please post back here and look for lines in the text beginning
(EE) . What do they say?
*3*
3) You get a 'command not found' message or similar - X is not installed and you will need to install it. This is unlikely, if you chose the default installation. *2*
Hope this helps, let us know what happens.
*1* no space between start and x
*2* the default install is advisable for newer linux users
*3* This info can also be found in /var/log/XFree86.log or similar but it is easier to read it from the screen.
Mandrake Users: What version of X comes with Mandrake 8.1? If it is 4.0.1 or greater (which I strongly suspect it is
) then installing nvidia drivers is no hassle. If it is version 4.1 or above it *should* be compatible with the GeForce Vcard.
