Yesterday I bought a combo,
MLB socket A asus a7pro atx,
amd socket A Thunderbird 1ghz.
I get home, gut my current system and put in the board. I made sure I have all the required things and made sure my power supply was the right kind, it was.
So I start hooking everything up. Everything looked fine. So I turn on my system.
It loaded up fine, asked what Windows OS I wanted to start. So I pick win2k.
It says it can't find it. So I had to reboot. Pressed restart. When it started up again it didn't show the list this time, it just went to black.
I played around with the cords hooking it every which place, still didn't work period. I played in the bio's. Nothing helped it. Sometimes I couldn't even get the monitor to turn on.
I set it up to read the a:\ first. It reads the boot disc and I check if I can access my hd's. I can, I can see all the files on all of them.
But if I do edit, or scandisk. It freezes or shows weird characters.
If I try to install windows it freezes during scan disk. In win2k it just shows the main windows 2k screen during the install process.
I never used an ASUS card before and i'm hoping it's something simple.
Please please if you can help me please do. I don't want to overclock, I know this is a place for overclocking, but someone told me to post here.
If you need any other info to help me out please ask.
Thanks guys.
Thanks guys.
