After I switched the FSB to 133 I cant seem to install anything off DVD rom without CRC errors or corrupt files. I ripped the hard drive & DVD rom out and tried them together in the crappy compaq/family/testing computer. It worked fine- Installed a few games with no CRC errors. I plugged them back into my computer and switched the fsb back to 100 and I could install fine. Switched it back to 133 and got CRC errors again.
I havnt done too much because Im not sure what CRC errors are. The only thing Ive tried is up the voltage and make sure the DMA in bios was set to auto, but it hasnt helped. I have noticed through the IDE controller (windows) that the hard drive is set to DMA Ultra 4 while the DVD is set to DMA Ultra 5. Would this be causing the problem? I cant figure out how to change the setting. The only thing I can do is choose PIO or DMA modes.
System:
AMD XP 2200
MSI KT4V
EPO x16 DVD
WD 80gig
ATI 9700
1gig XMS3200c2
Some cheap AudioExcel 5.1 sound card
No overclocking (yet) BIOS set on default w/ exception of FSB manually set to 133
System:
AMD XP 2200
MSI KT4V
EPO x16 DVD
WD 80gig
ATI 9700
1gig XMS3200c2
