Hello,
I just got a great price for a new ryzen 3970x which i paired with the ASUS ROG Zenith II Extreme
I`m surfing the net to find good 64GB 3600 memory, and i simply cannot understand how pricing works.
1. Some 2x16 Kits if i would buy 2 would be cheaper then 4x16GB kits! ... as far as i know pairing 4 modules of the same brand will work in quad channel\
2. there are loads of kits out there that are 19-19-19-38 which are way more expensive then a 16-16-16-36 kit from Gskill. Ex:
CL16 Kit 420E
CL16 Kit NEO's - 672E
Let's not go Corsair which cost upwards to 1000E and don't even have CL16 timings...
What am i missing?
EDIT: I would guess B-Die's would be more expensive. but upon searching the B-Die chips are only 2x16GB and they somehow are the cheapest!
I used: https://benzhaomin.github.io/bdiefinder/
This is so weird...
Thanks in advance!
CL16 Kit 420E
What am i missing?
This is so weird...
Thanks in advance!
