Please help me, please, please, please help me...
takiwa
On the mobo I have got here, I am having a big problem. The hdd came with 95 on it, and it worked fine. I was gonna put 98 on it, so I booted to a 98 cd, and ran fdisk and a format...the format wouldn't run on this comp, so I out the hdd in my comp and formatted it. I put it back in this machine, and it won't detect the hdd in the BIOS. I tried this hdd in my machine...it runs fine. I tried another hdd in this machine, and it won't detect either. What did I do to this mobo to make it stop detecting hdd's? Does it have something to do with the FAT16 file system? And if so, how do I correct it? I really need help on this one...or I'm in deeeep doo-doo...
RainMaQer
3D God
Fort Wayne, Indiana
Sounds like the IDE channel died bro... does it work on either channel? Or does it just not work PERIOD? Anything look odd or missing around the IDE channel... fried pathways or something... maybe missing pins? Did you make sure your not putting the ide cable in backwards... mobo or HD side.
takiwa
takiwa
the cd rom works in both channels, so I don't think it's that...it just won't detect a hdd when i put it in there...any hdd in my house (i have 5)...
Yodums
Senior Member
Ottawa, Canada
Check the following:
The cable
The jumper in the HDD
The power in good
The motherboard may need some kind of flash to identify the FAT32 partition, or something..
REPLY ASAP~
Teacher_Doug
Scotland, N.E.Fife
You said you ran fdisk...did that work? before you tried to format
takiwa
takiwa
get this crap...never seen anything like it...the hdd ONLY works in secondary IDE channel...no matter how you set the jumpers...CD will work in either...thanks Rain for the tip, found out after I checked behind myself...still don't know why, though, but who cares...it's working!!!!!
stool
Senior Member
Albany, NY
Had the same problem with a Soyo board. The main IDE channel would detect CD and Zip but no hard drive. Baffling. A BIOS update did nothing to help, either. I have to assume its a hardware problem, but since I didn't discover there was a problem until the warranty crapped out, nothing to be done.
