Ok, heres the story. Ive got intermittant reboot problems on this motherboard. First I thought it was power supply, so I changed it. When it worked for awhile (1 hr tops) I put the old one back in. The old one worked great - until now.
When I say intermittant reboots, I mean it completely. It even reboots in the BIOS. Sometimes it doesnt detect my main HD, but cold booting fixes it.
To get the machine back up during one of these rebooting outages, I keep it unplugged for at least an hour, then it will usually amgicly work again.
And I DO have a "bursting" capaciter, but it's only one. Do you think this is the problem?
Also, Is a power supply fan speed of 1500 - 2000 rpm acceptable? I dont think so, Should I replace it?
Thanks In Advance.
Anyway, below are my relevent specs straight from Sisoft Sandra, with comments:
Thanks In Advance.
System
Manufacturer : Seneca //??? Its MSI...
Model : MS-6330 //Also K7T Pro, I belive
Mainboard
Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD
MP Support : No
Model : MS-6330
System BIOS : 10/07/2002-8363-686A-6A6LMM4AC-00
Chipset : VIA KT133/A
FLASH Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Bank0/1 - BANK_0 : DIMM 256MB
Bank2/3 - BANK_1 : DIMM 256MB
Bank4/5 - BANK_2 : Empty
Chipset
Model : VIA Technologies Inc VT8363/5 KT133/KM133 System Controller
Bus(es) : ISA AGP PCI USB i2c/SMBus
Front Side Bus Speed : 2x 100MHz (200MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 133MHz / 1x 133MHz
IO Queue Depth : 4 request(s)
Logical/Chipset Memory Banks
Bank 0 : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 1 : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 2 : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank 3 : 128MB SDRAM 7-1-1-1R 4-1-1-1W 3-3-3CL
Bank Interleave : 4-way
Speed : 1x 133MHz (133MHz data rate)
Multiplier : 1.33x
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : Kingston 2MX64PC133CL3 168P 020D5D00 256MB 16x(16Mx8) SDRAM PC133U-333-542 (CL3 upto 133MHz) (CL2 upto 100MHz)
Memory Module 2 : Siemens HYS64V32220GU-7 01C2A080 256MB 16x(16Mx8) SDRAM PC133U-222-542 (CL3 upto 133MHz) (CL2 upto 133MHz)
// I had no idea you could get this info from memory, If I did i'd have bought the same brand...
Environment Monitor 1
Model : VIA 686PM ISA
Version : 10.00
Mainboard Specific Support : Yes
Temperature Sensor(s)
Board Temperature : 24.1°C / 75.4°F
CPU Temperature : 46.9°C / 116.4°F
Power / Aux Temperature : 30.3°C / 86.5°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 5114rpm
Voltage Sensor(s)
CPU Voltage : 1.78V
+3.3V Voltage : 3.33V
+5V Voltage : 4.93V
+12V Voltage : 11.71V
AGP Bus(es)
Version : 2.00
Speed : 66MHz
Current Data Transfer Rate : 4x 66MHz (264MHz data rate)
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : No
Aperture Size : 128MB
Expansion Slot(s)
PCI (8h) : PCI 32-bit +5V FullLength Available
PCI (9h) : PCI 32-bit +5V FullLength Available
PCI (Ah) : PCI 32-bit +5V FullLength InUse (Macronix International Co Ltd MX98715/25 Fast Ethernet Adapter)
PCI (Ch) : PCI 32-bit +5V FullLength Available
PCI (Dh) : PCI 32-bit +5V FullLength Available
PCI (Eh) : PCI 32-bit +5V FullLength Available
AGP (8h) : AGP 32-bit +5V FullLength InUse (Nvidia Corp GeForce2 MX/MX 400 [NV11])
Port Connector
PRIMARY IDE : None - ATA / None
SECONDARY IDE : None - ATA / None
//I have 2 HD and 2 CD Drives on the above two ide ports...
FDD : 8251 FIFO - Floppy Disk / None
COM1 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 - 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP - DB-25 pin female / DB-25 pin female
Keyboard : Keyboard - None / PS/2
PS/2 Mouse - Detected : Mouse - PS/2 / PS/2
USB : USB - None / None
Processor
Model : AMD Athlon(tm) processor
Speed : 851MHz
Model Number : 851 (estimated)
Performance Rating : PR1132 (estimated)
Type : Standard
L2 On-board Cache : 256kB ECC Synchronous Write-Back
Video System
Monitor/Panel : Default Monitor
Adapter : NVIDIA GeForce2 MX/MX 400
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : MAXTOR 4K080H4
Hard Disk : Maxtor 5T020H2
CD-ROM/DVD : PIONEER DVD-ROM DVD-115
CD-ROM/DVD : RICOH CD-R/RW MP7060A
Logical Storage Devices
1.44MB 3.5" (A: N/A
System drive (C: 5.0GB (2.4GB, 48% Free) (NTFS)
Program files (D: 11.3GB (2.7GB, 24% Free) (NTFS)
File storage (E: 71.5GB (3.6GB, 5% Free) (NTFS)
Incomplete downloads (F: 3.0GB (2.6GB, 87% Free) (NTFS)
CD-ROM/DVD (G: N/A
CD-ROM/DVD (H: N/A
Peripherals
Serial/Parallel Port(s) : 2 COM / 1 LPT
USB Controller/Hub : VIA USB Universal Host Controller
USB Controller/Hub : USB Root Hub
Keyboard : Easy Internet Keyboard
Mouse : Logitech-compatible Mouse PS/2
Human Interface : HID-compliant game controller
MultiMedia Device(s)
Device : VIA AC'97 Audio Controller (WDM)
Device : Standard Game Port
Printers and Faxes
Model : VentaFax
Model : Canon LBP-430
Operating System(s)
Windows System : Microsoft Windows 2000 Professional Version 5.00.2195 Service Pack 3
Network Adapter(s)
Network Drivers Enabled : Yes
Adapter : Macronix MX98715 Family Fast Ethernet Adapter (ACPI) #2
