- Sep 6, 2009
Ok, so I've read all the guides and such in the stickies, and here is what I came up with. This is my first water cooled set up. This will be for a i7 920 on the EVGA Classified board. Plan to run this loop for shipset and cpu only, with a second for the graphics down the line.
Hoping to get around 4.0 Ghz with this.
Plan to run 1/2" tubing for the loop.
Is there a better water block for the CPU?
Not sure what to use for the liquid. Please recommend. Read the sticky and it looks like PrimoChill PC ICE is a good choice. What should I add to it to stop growth?
Not sure if I need the tubing I selected. Would prefer something that is uv blue, but want the benefit of anti-microbe from the silver tubing.
Do I need any fittings or anything? What do I use to attach the hoses to the barbs? Are compression fittings better? I'm willing to spend the money on them if someone can recommend any to me.
Getting 12 feet of tubing. Is that enough for this loop plus a second graphics card loop down the line?
Do I need the shroud? Looking for low noise solution here, so if it will help I will buy it.
Lastly, and most importantly(I think), is this creating a mixed metal loop? I think everything is copper but I see a lot of different materials in the items descriptions, so i'm not sure what is actually making contact with the water.
Edit: Changed to proper size tubing. Unfortunately, it is out of stock. If anyone knows where I can buy it that would be great. Will update with fittings shortly.
Edit: Added 8 fittings for 1/4 to 1/2 and 10 clamps. Added 4 fittings for radiators. Eventually going with two loops so 4 fittings.
Thanks!
This is the case it is going in to, putting my old computer in there as well for web/db server(yes I know it is expensive):
Ascension - Duality (Mirror Black Powder Coat)
Loop:
EK EVGA 3x SLI X58 Classified Full Board Cooling Block Kit
Swiftech Apogee™ GTZ CPU Waterblock
ThermoChill PA120.3 3x120mm High Performance Radiator - 15mm Spacing
Laing DDC-3.2 (18W)/Swiftech MCP355 Inline 12V DC Pump
XSPC Dual DDC Bay Reservoir
Tygon® Silver Antimicrobial Tubing 1/2in. ID 3/4in. OD # AS600038
KwikCut Advance SL100SS Stainless Steel Tube Cutter - Orange
EK High Flow Fittings G 1/4 to 1/2in. ID Barb - 8 TOTAL
Breeze Miniature Hose Clamp 7/16 in. to 25/32 in. - 10 TOTAL
EK High Flow Fittings G 3/8 to 1/2in. ID Barb - 4 TOTAL
Thanks!
Loop:
