Hello Folks, UPDATED: 06/26/2003
As you can see I am learning a lot from this thread and I am updating the post everyday with modifications here. So, before replying, please, repeat please, verify and do the sanity check of this system. Also, mention, if I need to gather some more stuff!
Plese check http://chimputer.tripod.com/ where I have put up the system components that I am planning to buy and eventually assemble. After learning from you folks about memory, I did some research and put up a skeleton for my gaming system. Please provide your thoughts about it. I am open to any suggestions that you can provide me with.
You can flame at me if I sounded like a moron. But, do provide suggestions on the system components that is on my webpage.
If you could not visit the webpage, here's the list. Tell me if I need to rethink about some components or need to get some additional ones to have a decent gaming PC. I have some components which have multiple choices. For example, motherboard, hard drive etc. Please suggest one of them.
IMPORTANT: Please suggest me a good monitor for my gaming PC under $700.00. I am really confused there. I believe, monitor is the most important component in any computer system as we interact with it the MOST!
Processor - Intel(R) Pentium(R) 4 Processor 2.4cGHz, 800MHz FSB, Socket 478 $175.00
Hoping to eventually overclock it to 3.0+ GHz, if that's possible, with my setup. Will need your help on that!
Motherboard - ASUSTek P4C800 / ABIT IC7-G, Intel 875P chipset for Socket 478 800MHz Canterwood ATX Motherboard $190.99
Memory - 2 x CORSAIR MEMORY XMS Extreme Memory Speed Series, Low Latency 512MB 64MX64 CMX512-3700PT Platinum With Silver Heat Spreader / 2 x CORSAIR CMX512-3200LLPT 512MB DDR400 XMS3200 Low Latency SPD Memory w/Platinum Heat Spreader $300.00
Case - CHIEFTEC Server Chasis (Aluminum Workstation Tower with Plastic Front Cover) BLACK COLOR w/ Side acrylic window and a Case Fan on Side Window with 2 x Front USB2.0 and 1 x Firewire IEEE1394 ports (newegg.com Model AX-01BLD) $68.00
Power Supply - Sparkle Power 550W Power Supply (newegg.com MODEL FSP550-60PLG - OEM) $100.00
Round Cables - COOLER MASTER's UTC-A24 (EMI Shielding) ROUND, 24-Inch, ATA133/100/66 IDE Cable. 3-Connector. ( BLACK ). with Chassis Ground Wire $50.00
Cooling System CPU Fan | HDD Cooling | HeatSink | Specialty Cooling | Case Fans | Lighting -
1x 92mm Panaflo M1A / VANTEC's Tornado (Double Ball-Bearing) Fan
2 x Panasonic Panaflo Axial Fan 80x80x25.5mm, Ball Bearing, DC 12V, 3.24W, 3450 RPM, 46.9 CFM, 38.2 dB-A Model: FBA08A12U - OEM
BLUE COLD CATHODE LIGHT KIT
Vantec NXP-201 (BLACK) Nexus Fan Controller Panel
Zalman CNPS6500B-AlCu Pure Aluminum and Copper combined CPU Cooler for Socket 478
Thermalright SLK-900-U ( Heatsink ONLY ). All Copper heat spread
Thermaltake All COPPER Heatspreader / Heatsink for DDR and SD RAM
Arctic Silver's NEW Premium High-Density Thermal Compound: Ceramique . 2.7-gram( ~0.8 cc. ) tube
$150.00
Storage Media - 2 x Hard Drive Western Digital Raptor WD360GD 36.7GB Serial ATA 10,000RPM Hard Drive w/8MB Buffer $137.50 x 2
DVD Drive - LITE-ON XJ-HD166S 16X DVD ROM Drive - OEM 48X $31.00
Video Card - ATI Radeon 9800 Pro 128MB DDR DVI TV OUT 8X AGP $350.00
Monitor - Sony P1130 FD Trinitron 21" CRT Monitor / SAMSUNG SyncMaster DynaFlat 955DF 19" Monitor $650.00 / $199.95
Sound Card -
Creative Labs Sound Card Audigy 2 Platinum
Creative Labs Black Face Plate Kit for Sound Blaster Audigy 2 Platinum Drive $190.00
Speakers - Klipsch ProMedia 5.1 $300.00
Network Card - Instant Gigabit Network Adapter $20.00 <MAYBE>
My Budget for core components excluding monitor: $1700 - $2000.00
Thanks,
Rexian
$150.00
Sound Card -
Thanks,
Rexian
