This is one that needs answering by *foo. If you don't get a response here then post in the Intel Boards sub-forum.
Short answer is - you won't be able to overclock a D845GBV (Brownsville) without a hardware mod. *foo recently modded a D845GBV (I think) to run a 200MHz (800FSB) FSB speed so if anyone knows about this stuff it's him.
Being able to run an overclocked Intel board like the D845GBV is something I'd LOVE to do. I'm sick of the crap quality and non-existant validation you get with Taiwanese boards and the only thing stopping me from using an Intel board as my main rig is lack of overclocking features. I use a D845GBV in my server now and it's the most rock-solid, problem-free board I've ever used. Since it replaced my Abit SA6R my server has been 100% - with the Abit board it was 50% on a good day.
ok thx, by the way, if i change to new mobo with 845pe, which brand is better to overclock? because i have intel 2.4b cpu,i have read some msg, they said if cpu overclock up to 3.0,then i could use hyper-threding. is that true?
No, it's not true. You need an HT-enabled P4 to use hyper-threading - that means the 3.06GHz P4 only. The only other chips that have hyper-threading enabled are some ES P4 chips (that have HT unlocked) and some special P4's (2.8's I think?) that Intel released to developers.
Next year we'll see some lower-speed P4s with HT-enabled (2.4, 2.53 etc.) but not at the moment.
Speak to *foo about the D845GBV mod. I assume it's too tricky for us mortals to try but you can ask him anyway. *foo posts in this forum or you could just PM him (do a username search).
