K
Kryten
Guest
On my way to work this morning I started thing about pelts and their overall efficiency, on a reasonably slow CPU i.e pentium 2 / 300 , which obviously wont produce the same heat as a say 1.4 gig Athlon, is the efficiency of the same size pelt reduced, i.e using the same pelt on both CPU's
the reason I ask is because if there is more heat going in, it must have to get rid of that heat plus any potential difference, if you start with a lower heat it must dissapate easier.
just interested in your thoughts....
