- Feb 25, 2001
i just bought MSI K7T Pro 2a, i needed to upgraded the BIOS to solve imcompatibilities with Windows 2000. After installing the new BIOS, i ended up with a blank beeping screen. I returning the mobo to the shop n waited for refund. I e-mailed MSI and got this:
support wrote:
Upgrading the BIOS Is not guaranteed by the manufacturer nor the distributor. But if you experienced some problem with your motherboard some BIOS upgrade will solve those problem............
Does this mean that i you have a 1.2Athlon with a MSI-6330 mobo n u need to upgrade the BIOS they wont give u a guarantee if it fails? its like giving out a faulty product and giving you glue to fix it and if the glue didn't stick well, they would just say sorry!
Beware especially those who are using Win2000 with MSI-6330!!! This is bad tech support =( i was very satisfied with the mobo until this problem arised =(
