PoP Up Killer Which one?
Mr.DLucey
I need a pop-up killer:
1-Which do you use?
2-Why did you chose it?
3-Does it get all of them?
i am using Ad-Shield but actually it wont stop several pop-ups... i dont know exactly why. maybe because those are not java scripted or something.
i chose it because a member recommended it, but ive read nice things about the Pop-up Stopper after then. next time this is the one im gonna try.
one thing i read about it is that many ppl reported dramatically lower page-load times with the version 2.6 - so they suggest versions 2.4 or 2.2.
you can get it here
Phoenix 0.4 browser stops pop ups cold.
'Pop Up Killer' 1.45.4 is the last build and works great with Opera6 but not with IE.
'Pop up stopper' works well but only with IE.
I use a Phoenix and Proxomitron, nothing get through. Proxo takes a little getting used to but it is a very effective software proxy. imo
