K
Kryten
Guest
I have seen arguements for both sides in here but the question that still haunts me is ... the difference typically recomended is around 10-20% If we were to use a typical figure of 150CFM this would equate to 15-30CFM, now if the difference was at the top end (30CFM) this is equivalent to 1x80mm fan, now what I would like to know is with all these extra holes that come in the case (using my tower as an example)
it has in the rear plate 36 x 3/16 holes + provision for 2 x 80mm fans, in the front cover down the bottom it has a slit 4.25' x 1' now with all these holes and only 30CFM pressure difference how can anyone honestly say that the have positive or negitive pressure in their case.
I realease that some of you may have gone to extreme mods to remove all the holes but has the average person claiming negative or positive pressures.
