- Jun 12, 2001
- Port Charlotte, Florida
Was crusing my usual news sites and found a site that had purchased 4 1800+ MP's. Turns out that one of them was registering as an 1800+ XP. They ran the part number through AMD Tech Support and sure enough it was a mispackaged XP.
So far this has only been noted with the 1800+ and AMD is investigating.
Word to the wise, if you plan on getting an 1800+ MP (or two) double check the part numbers.
I'll put up some linkage if I can find it again.
