Possible Case Options
Mico
Marrietta, GA
I plan on running a VIA Abit motherboard with an AMD 2200+ (possible overclocked at a later date, nothing major, if then) and I was wondering if anyone out there knows of a place where I can buy BLACK ATX-mid towers for about $50 (or cheaper!!)that look fairly decent. I am open to adding fans and such. I have searched NewEgg.com, Xoxide.com, and pcmods.com, and found a couple that look good, I just want to shop around.
CrashOveride
Beijing, China
i would have linked to directron as but some one has :D one thing i would say is: dont use the PSU you get with a cheap case for anythign but a cheap computer! it could cause problems make sure you get a good PSU if you get one with a case or use one you have:D
texuspete00
Get a 2100+ tbred B.. better OC when you go that route. Near identical performance until then. ;)
Oh you may already have the cpu... nm then. Chieftec cases are good and cheap. I think Antec cases are actually good deals when you need a ps b/c no one should skimp here. If not an OC'er and dont need the watts, still want quality. To get a case and really good PS for like 70... not too bad.
RCtruckguy
columbus,ohio
yea thats a great PSU, it also goes by sparkle witch is one of the best quality ESPECIALY for the price and they are a little under rated, about 30%. the 350 modle is the best~Alex
