- Dec 13, 2015
I'm looking at a new build. I'm thinking an ITX build. I've never had a case that fit on my desk before. I think that would be pretty cool. I'm not sure about components, though. I'd like to overclock on air (possibly with the Dark Rock Pro 3 from Be quiet! I've read good reviews about that cooler...if anyone has other suggestions for air cooling, they are welcome...I'm not quite ready for water cooling yet. The possibility of leaking scares me a little bit). I was also thinking of switching from a 2.5" SSD (which I have now) to an M.2 (1 or 2 TB...suggestions here for good drives would be welcome, as well...I have a Samsung 2.5 SSD right now, I could just stick with Samsung moving to an M.2...I haven't had any complaints about the SSD I have). I was thinking about the M.2 because with an ITX build, of course there is not much room, and I'd like to have as much room as possible for the video card. I have 16 GB of memory now, and I'll probably stick with that. That seems to be a good amount for a gaming pc (which is what I'm trying to build).
As far as the card goes, I've been reading that AMD is working on a 7 nm process for either a refresh of Vega or a new Navi card, or both, for next year. I've thought about the RTX cards from Nvidia, but even after they came out at really high prices, I've read that Nvidia will possibly come out with another new card to compete with the 7 nm card from AMD, and that the RTX series will be the shortest life span of video cards Nvidia has ever had. So I'm not sure how much room I would need for the video card in an ITX case, and I won't look to really build this until next year when AMD's new cards come out. However, if I could get some suggestions for cases with good airflow, that people have had success with using aftermarket air coolers (where the coolers actually fit in the case), that would be great. Also, I guess I will need a recommendation for a PSU. I have looked at SFX PSU's, but none of them I've seen are very powerful. The largest watt PSU I see on Newegg for the SFX form factor is a 600W from Corsair. Am I correct that an SFX PSU is really the only one that will fit in an ITX case? I have seen reviews of a few cases, and they can use bigger PSU's, but cable management is not great. I guess I wouldn't need it to be very powerful. Right now I'm using an 850 watt PSU from EVGA. I don't mind stepping down on wattage a bit, I would just like it to actually be able to run everything in the case.
Lastly, since this is my first ITX build, a recommendation for an ITX mobo would be great too. To go along with that, I was thinking of switching from Intel (which I have now) to AMD Ryzen for this new build. I know Intel just released the 9900K because AMD has finally offered up some competition in the CPU market, but Ryzen seems to be more competitively priced for just about the same performance (except perhaps the 9900K, but that is too expensive for me at this point...$580 on Newegg). So what do you guys think? A Ryzen build, or do I stick with Intel? I'm using an i7 sixth gen processor right now, if I wanted to keep with Intel, I guess I could upgrade to a nine or ten series i7. Is the Ryzen 7 (or 5) competitive now for gaming machines, or is Intel still good?
I know this is a lot to ask at once. Any suggestions/responses I can get would be much appreciated.
