- Oct 14, 2002
A friend of mine just asked me if turning the priority up in the task manager thing on 3dmark 2001 in XP would increase the scores. I'll probably try this when i get home this evening but since i'm at work, I figured I would ask you guys to try to get him an answer quicker. Thanks guys.
also, while i'm thinking about it, i'm trying to increase my 3dmark score, which in all honesty is horrible right now. My high score is 4665 with the system in my sig. If I added ramsinks to my vid card, would that make a noticable difference or would I need to worry about the GPU more. I know the ramsinks definitely won't hurt it, but if that's all I can do right now, will that be enough to at least give me a slight boost? For now, I'll be happy getting 5000 which seems like it's going to be very hard to reach that without some sort of extreme cooling measures. Does anybody know where i can get a decent slot a mobo that allows fsb overclocking? That's a big bottleneck for me right now that i can't overcome since my mobo is ridiculously crappy. Thanks for the help.
