FEATURED Post your Cinebench R20 scores here!
Johan45
As some of you know Maxon has released an update to it's Cinebench benchmark, namely Cinebench R20. The update will take advantage of newer CPUs strengths like updated instruction sets etc..
I would ask that posters use this format UserName/ CPU/Cooling/ Score and I will update the OP to reflect your position in the rankings.
You can download this benchmark directly here Maxxon Cinebench R20 so no need for MS store
Anyone trying to use Windows 7 and getting an Entry Point Dll error you need KB2533623 from MS, this likely won't be an issue with a up-to-date OS
Results
Dr Emmett Brown / Threadripper 3990X / Compound Chiller + Heat Exchanger / 33179
DaPoets / Threadripper 3990X / Custom Loop / 31043
DaPoets / Threadripper 3970X / 4.4Ghz all 32 cores / Custom Loop / 19086
DaPoets / Threadripper 3970X / 4.2ghz all 32 cores / Custom Loop / 18237
DaPoets / Threadripper 3970X / Stock settings / Custom Loop / 17001
mllrkllr88 / 2990WX @ 4150 / Ambient Water Loop / 15430
cdawall / 2990WX @ 4150 / Custom Loop / 15032
DaPoets / Threadripper 3960X / 4.4ghz all core / Custom Loop / 14776
DaPoets / Threadripper 3960X / stock settings / Custom Loop / 14051
batboy / i9 10980XE / watercooled / 10680
PolRoger / Ryzen 3950X / Water / 10457
Notarat / 3950X / 4.35 AllCore / Water / 9946
Earthdog / i9-9980XE / AiO / 9943
Aleslammer / Rysen 9 3900X / Chiller / 8213
MaddMutt/i9-10940x/AIO/8126
jiccman1965/i-9 7940x @4.4/7946
batboy / i9-7920X / watercooled / 7394
DaveB / Ryzen 9 3900X / CM MasterLiquid ML240L AIO / 7275
Aleslammer / Rysen 7 3800X / Chiller / 5621
Brutal-Force/ i9-7900x / 4.7Ghz all 10 cores / Noctua NH D15/ 5561
Witchdoctor / i9-9900K / H2O / 5530
Kenrou / 3800x / Air / 5361
Dr Emmett Brown / i9-9900KF @ 5.288 GHz / 2-stage vapor phase change thermosyphon / 5322
Photosbykev / i9-9900k / H2O / 5092
Dr Emmett Brown / i9-9900KS @ 5.023 GHz / CORSAIR H150i / 5041
dguy6789 / Core i9 9900K / Noctua NH C14S / 4523
godevskii / [email protected] ghz + [email protected] mhz cl16 / custom WC / 4323
DaPoets / i7-8700k @5.4GHz -1AVX / EKWB Full Custom Loop / 4316
godevskii / [email protected] ghz + [email protected] mhz cl16 / custom WC / 4150
LRG5 Ryzen2700x / AIO / 4056
DaPoets / i7-8700k / EKWB Full Custom Loop / 4041
jguillen80 / i7-8700k @ 5.09GHz / Custom Water / 4018
Samael_00001/i7 8700K (Stock)/Air/3890
Kenrou / Ryzen 3600 / Air / 3842
DaveB/Ryzen 7 1700X (8C/16T) @ 3.9 GHz - 3811
testyoldpower / Ryzen 5 3600 (1.15V @ 4.2GHz) / NH-L12S (Air) / 3809
Contra/i7 8700k/Air/3360
Johan45/ R5 2600/ AIO/ 3267
unsafesteagle / Intel 7800X/ AIO / 3121
unsafesteagle / 1600X Ryzen/ AIO / 2851
Culbrelai / i7 8086k / Stock / Air / 2826
freakdiablo / 6700k @ 4.4 / Air (Scythe Ninja 4) / 2256
freeagent/X5690/Air/2165
ultra TACO / X5670 / watery / 2013
freeagent/3770K/Air/1757
Dejo/ 6770HQ/ stock air/ 1730
Kenrou / FX-8370 / Air / 1650
madman75/FX-8350/212 EVO/1534
DaveB/ Xeon E5-1620 (4C/8T) @ 4.3 GHz - 1527
Mr.Scott / i7-930 @ 4.0 / Air / 1356
storm-chaser / 1600T Thuban / AIR / 1265
storm-chaser / Q9650 / AIR / 1021
habbajabba / A10-7850K / AIO / 813
Johan45
OK, Wi7 works BUT I don't use a fully updated version and had an "entry point Dll. error" I found the appropriate KB which I will post in the OP for anyone who runs into the same issue. As usual Win7 scored just a bit better than Win 10, there were no tweaks applied and it's the identical system and settings aside from the OS
Win7
Win10
DaveB
Senior Member
Xeon E5-1620 (4C/8T) @ 4.3 GHz - 1527 :popcorn:
Ryzen 7 1700X (8C/16T) @ 3.9 GHz - 3811 :cheers:
mllrkllr88
@UltraTaco...you have the best name ever, I laugh every time I see it!!!
Nice competition! I have an 8700k setup on the bench right now but I should be able to get the big AMD chip setup before the end of the competition.
freakdiablo
Was gonna run it on my HTPC even though it's stock, just to get a 2600 up there for reference, but looks like you've already got it covered, Johan.
Mr.Scott
Beamed Me Up!
My Daily
DaPoets
mllrkllr88
How about a little red on top? This CPU is such a beast to tame, with a mere 1.30 V, the core is hitting 90c using a top quality loop and fairly chilly ambient temps.
