FEATURED Post Your Cinebench R23 Scores
salvinipcs
As some of you know Maxon has released an update to its Cinebench benchmark, namely Cinebench R23. The update will take advantage of newer CPUs strengths like updated instruction sets etc..
I would ask that posters use this format UserName / CPU / CPU Speed / Cooling / Score and I will update the OP to reflect your position in the rankings.
SCORES:
gregmacknass / 2 x Intel 8280 platinum's / 3.1 GHz / Custom Water / 45449
Johan45 / Ryzen 9 5950X / 4.9 Ghz / Chilled Water / 32897
salvinipcs / Ryzen 9 5950X / 4.7Ghz / AIO / 31 604
Brutal-Force / i9 10980xe/ 4.7Ghz / Air / 26755
David / Ryzen 9 5950X / 4.0GHz / AIO / 25849
unsafesteagle / i9 9940X / 4.5Ghz / AIO / 17448
Kenrou / Ryzen 7 3800x / 4.4Ghz / Air / 13795
freeagent / Ryzen 5 5600X / 4.7Ghz / Air / 12263
salvinipcs
How would I go about starting one? my best score is 31604 5950x (16C/32T) @ 4.7 GHz on all cores with 32 GB (4x 8GB) RAM at 3600 MHz. cinebench R23 + Benchmate - 31,604.PNG
gregmacknass
My result
Here is my submission to this little battle. I was never given the result popup like yours. Edit: ahh I see you used the benchmate version. Mine was run on the full normal version.
gregmacknass / 2 x Intel 8280 platinum's/ 3.1 GHz / Custom Water / 45449
Score 45075 2x 8280 platinums 192GB memory
salvinipcs
Awesome score! You have to make the minimum test duration none the original one just gives you the score too:)
gregmacknass
Yeah, I figured that on my second try. I ran it again with the benchmate version and got 45700 or so. I might put that up later as my high score.
David
Forums Super Moderator
That is very odd that cpuz is showing 1 core and 1 thread. And several other fields blank. I have never seen it do that before.
It's the Asus branded version of CPU-ID but I think it's out of date - it doesn't recognise the CPU (v 1.93). I need to install a newer version ...
unsafesteagle
Basic Cinebench Run
Hey Guys,
Basic cinebench multi thread run using the intel system from my signature.
Tks.
unsafesteagle / i9 9940X / 4500 MHZ/ AIO Water / 17448
Robertspcs
10980xe overclock
10980xe overclock to 4.7 fully watercooled
Robertspcs / i9 10980xe/ 4.7Ghz / Water / 26879
Woomack
Benching Team Leader
At least it's 110°C on 18 cores, not 8 like for my 11700K with the 360 AIO :p
