- Jul 14, 2003
Hi all. So i had an idea of doing up an experiment on using a Dell DA-2 power brick, like the ones people use with the Akitio Thunder 2 eGPU setups, to externally power a GPU for use cases like people wanting to run a bigger GPU in a prebuilt PC or OEM that doesn't have a standard type PSU.
When i had this idea, i remembered this power brick is used for a similar purpose (as mentioned above), so i sought to adapt it. Needed the ebay adapter you'd use with the Akitio Thunder 2 for it since it switches the brick on and adapts its plug to a 6+2 pin connector, then an adapter that split that into two 6+2 pin connectors for better usability, and I successfully tested this on my GTX 970 atop my test bench PC.
However, when i turn the PC off the power brick obviously stays on (green light) unless i unplug it from power, or remove the first adapter that forces it to be switched on. Will the power brick being turned ON have any affect on the GPU while it is off? Will it fry anything? For you Akitio Thunder 2 owners (if any of y'all here), does the Dell power brick stay on even when your gear is all turned off?
Thanks in advance!
Thanks in advance!
