- Aug 1, 2002
- Michigan
Still a few months away but one thing that could trip me is the power requirement to run 8 computers at once.
I'm planning on Sandybridge CPUs, probably with H67 mobo as I'm not planning to overclock and H67 would have onboard video, which would save me about a grand from not buying 8x video cards.
8x H67 (or Z67 if they come out and are decent), 8x 2500 (not K), 8x HDDs, using USB drive to install Linux. I get the impression at most 300w would be needed each, would that be about right?
That would mean about 22 amps total my current house wiring won't be able to handle that unless I unplugged everything else, and with solid wood walls all around, running a new 110v line is not an option. Wiring in my house is about 50 or so years and multiple rooms are wired to single breaker. 3 computers and everything in my room is half of the total 20A max, leaving a scant 10A left for other bedrooms, living room, and bathroom. If someone used a hair dryer while I have all 3 computers on, the breaker blows.
However there are unused 220v line that I can tap into, and 220v feeding 8 computers would reduce current to about 11A (amp x volts = watts) and defiantly doable. Most PSU has either manual 110/220v switch or auto switching and should be covered.
Am I right so far?
Ok, next: computer power cord for the PSU in USA are generally for 110v outlet. The 220v outlet in USA aren't normally used for computers so finding power plug for USA 220v ro computer PSU would be real hard. Would I be better off if I tried some European style plug as computer power cord exists with European plug? I can see loads of them plus power strips with European plug on various online sources cheap enough.
Alternately I can defy the USA standard, use standard 110v outlet wired to 220v circuit but have them painted in like red (with red plate) and put label warning it is 220v not 110v? If the inspector decided on a surprise visit, he'd probably have a heart attack, then have me drawn and quartered for this practice.
Am I right so far?
