power for case fans(psu or mobo)(3 or 4 pin)?
augustwest
The Darkest Star
should any of my case fans be receiving power from my motherboard or should they all be hooked directly to the psu with 4 pin connections? my case is going to have 4 case fans and i need to know whether they should have 4 or 3 pin connections before i make a purchase.
thanks for all the help folks
Depends on their power drain. Most mobo fan headers can take under 3 W safely, but if you have the spare power connectors, go for the 3-4 pin connectors.
i will have only one spare 4 pin connection coming from my 300 watt psu. my mobo a SOLTEK SL-75DRV5. it hasent been delivered yet so im no sure about the connections i will have on it. can i run more than one fan off of one 4 pin from the psu? and what type of connection does the motherboard use for fans?
Well, if you get a decent cable, it will probably have a connector on the other side of it, so you won't lose a 4-pin connection (meaning you can plug in another device, keeping the plug free).
Most motherboards use the standard 3-pin configuration for CPU and case fans.
do you know anything about the SOLTEK motherboard that i have? how many fans do you have running off of your mobo?
thanks for the help
Most likely, yes. My mobo uses 1 for CPU, and 1 for the Via northbridge fan.
You'd have 3 connectors on the motherboard, but I still recommend powering them through the 4-pin connector, unless they draw little power and you want to monitor the case fan's RPM.
It is best to hook it up to the PS in my opinion, I rarely use my MOB hookups. Less wires to deal with is better, and one chain of wires is better than five...
Futura
