I'm completely new to actually setting up dual systems, but I'm getting ready to set up 2; my question is simply: will I need two PSUs, or will one do well enough on its own?
The water cooling pump has its own powersuplly, no? That would mean that your cooling system consumes very little power compared to a fan cooled system.
Get a single good one with as many watts as you can afford(at least 400).
didn't think about the pump's own power supply, but now that I do think about it, is there a way I can get it to run from the PSU? (I want to have less cables coming out of the case, not more lol)
highest PSU that Case-Mods.com sells, and that's where I'm buying pretty much all my stuff that isn't the actual electronics from there; so is that a good PSU by your standards? =P
I have a TTGI Silent Triple-fan 520W in my second dual MPX that has the same specs as the Vantec. It's available for $78 and $10 coupon codes are easy to find for Directron. A very good PSU for $68.
Enermax 550W in my main one and it keeps very stable lines with 6 SCSI drives, 2 opticals and all PCI slots loaded down...not to mention 120mm, 2X92mm and 4X80mm fans going in it. Should be able to grab one of those for around $100-120.
i like my Leadman 500w (Jon's died on him recently i belive tho), but im not running a huge power draining system, and it was less than 1/2 the cost of anything else with comparable wattage
