i guess now that i've read that a 78watt pelt aint gonna cut it and that a 172watt plet requires way too much power...24volts....my questions are....can i get banned for too many questions? =)
what size psu should i get for a t-bird w/c setup? i want to tap of the psu to run my eheim pump directly off the psu along with 4 120mm fans, and standard gear.
would perhaps 2 78 watt pelts be enuff to keep up with a oc'd t-bird? that way i could just get a p/s capable of 400+ watts and 12volts at 20amps and connect right to p/s? i'm so damn ee ignorant. i need to figure out this watt/amp/volt thing.
bottom line 2 questions:
1. what size p.s. for pump and t-bird outfit.
2. will 2 smaller plets add up to enuff cooling? any recs here? there is no way i can fit another psu in my case.
3. if 2 is logical, what size psu then?
sorry for the lame questions guys. i owe you all a ton.
