i have a celeron 300 going at 450, but i have heat problems.
i have installed two case fans, 1x100mm & 1x80mm from some old power supplies i pulled apart.
whenever i plug in a third power supply, the other two seem to slow down heaps and the system temp goes up by 5*, which is bad because that means i would be running 55*+, is it just a crappy power supply, or do i have to hook it up better???
nb: each one of the fans has it's own plug from the power supply
