I'm kind of new to ocing so I may not know what I'm talking about, but it seems like my PSU is to its limit and can't handle anymore o/c, I'm not sure though... it's a PP-303X, 300W (ATX). My system specs are
AthlonXP1700+ Tbred B DUT3C, 0311MPMW @ 2083 (166x12.5 - 1.675v)
A7V333 Rev 2.0
SLK-700 w/ YS-TMD fan + AS3 thermal compound
MSI GeForce4 Ti4400 128mb
2x 256mb Corsair XMS 2700C2 @ 2-3-3-5 - 2.8v
SB Live X-Gamer
DFE-530TX ethernet card
2x WD 60gb 7200rpm hard drives
Philips CD-RW 8x4x32x
I can't seem to even boot up at above 170 fsb (lol) no matter what I do (raised ram voltage, put timings to 2.5-3-3-6, raised cpu voltage) and I doubt it's my temps (cpu 34C idle, 39C load, MB temp 34-35) or my ram being pushed too far.
My voltages are 11.936 | 4.838 | 3.264 | 1.696
I run 3dmark2k1 for a few hours and they don't seem to fluctuate much, like + - 0.05 at the most but I don't even know if these above values are good or bad.. I don't have enough experience to tell if that indicates my psu being overloaded or what. Most people tell me my psu is way too low for what I'm running, but I'm having no crashes or reboots at my current settings, and the air coming out from the back of it isn't even hot (slightly warm). I had to raise my voltage from the stock 1.6 to 1.675 for stability over 1.9 ghz or so, otherwise I'd get blue screens while booting WinXP (I tried 1.650 first but that didn't work either).
So I'm fine now @166, but if I try to go a little higher (like 175 fsb), the system suddenly refuses to even boot. It boots and loads winxp fine with 170, but I haven't done extensive testing at that fsb. I know not being able to even do 175 seems pretty pathetic, so like does anyone have any clue what could be doing it, if not psu? I've seen most people go to 180+ (up to 192-195) with my board, and about that much with my type of ram too (some even with pc2100 corsair). I'm aiming for like 185x12/12.5 for long term usage and maybe slightly higher (if my board can) for benchmarking. I just don't see how I'm stable at one point and then I raise fsb slightly, it can't even POST all of a sudden (I assume it would start crashing/rebooting first, before getting to the point of not post'ing). Is this a common psu issue or something? Oh, and I haven't tried doing memtest or prime95 yet, but I hear some people that are perfectly stable, only get errors/crash when running prime95 sometimes so I don't know if I should trust it too much.
I'm probably going to get a fortron/sparkle 350W (would be enough?) cause I read those are like really good price/performance value, if this is for sure a PSU issue... but if anyone has other suggestions to try out, that wouldn't hurt either.
A7V333 Rev 2.0
SB Live X-Gamer
