powerful 92mm fan
NASsoccer
On a string I was held Senior
i live
can someone recommend to me a nice powerful 92mm fan. I currently have a 92 in the top of my case(blowing out), but it is not doing the job. It is a "low" panaflo. Are the hight ones too loud to anyone because i was thinking about going in that direction. Anyone with any other suggestions????
i agree...a 120mm fan would be better, however if you didn't want to hack @ your case i'd get the enermax 92mm adjustable fan @ crazypc.com 52cfm @ 32dba...if that's not strong enough for you then there's always the 92mm delta...110cfm :eek:
hmmm, i think the delta would be a little much:eek: . Actually there is plenty of room for a 120 because all i have sitting in the top bay is a DD5. But, for the moment i think i will look into getting a 92mm until i have time to take everything out of the case to get to cutting. hmm, how loud is the delta;).
it's 55dba...although, after reading the thread on the 120mm delta....it's pushing 190cfm @ 59dba...up to you...
well 55dba might be a little much because that is twice the level of the 92mm. Does anyone have a personal experience with the 92 delta. Also, does anyone have experience with the enermax? Don't know which yet but I think i am going to order a 92 and a 120 for later on.
there are plenty of 120mm fans out there pushing 100cfm + that dont make a lot of noise. dont remember exactly but they're in the hi-30's low-40's dba range. Any web based computer merchant offers a selection..
this i know:) but i am looking for the people that use the loud ones and the powerful ones to get their feedback. I have used a delta 60mm and i know it is loud and wouldn't tell anybody to use it. So i am looking for the same!!
Thanks for the feedback so far:D
