Powerful fan
J0HN
Hi all,
Here is my first post, with a odd question.
I need a powerful case fan, can be as loud as a 747. :D
It has to be 5v or less,
any size ok 60 - 120mm, but thin profile and LIGHT weight, just like stock AMD one.
Very high cfm / rpm, yet easy on battery.
Not too much $$$
I am building a portable device and need very high Air flow yet light weight. The stock AMD fan w/ 24v is perfect, but too high voltage and won't last very long.
If you know where I can find this monster, please let me know.
Thanks
John
B-auto
South Dakota
Enermax 120mm
Air Flow 67-94
3.6w
1500-2300RPM
A bit on the pricey side at $17.00, but your paying for big cfm's, low watt's, and reliability. Most fan's only have one of those trait's.
FrozenCPU
Cheesy Peas
Rotherham,UK
a stock amd fan, like all other normal case fans run off 12v, not 24.
your not going to get very high airflow with a low profile fan like the 10mm AMD one. i would suggest one of the TMD fans as there quite thin. but there only about 34cfm @12v. Your not going to get any better than that with a low profile fan.
