Establish a quick contact between the two pins of the connector you usually plug on your mobo (the one that goes on 'Power switch') using a srew driver or whatever metallic stuff you want.
You need to plug the ATX PSU connector from the powersupply into the ATX splitter that came with the vapo unit then hook everything else up like normal but instead of putting the other end of the splitter into the motherboard take a paperclip or a wire and connect the green wire to any of the black ground wires. THis will turn on the powersupply which in turn will turn on the vapo unit.
