Powerleap Hyperthreading Adaptor
NookieN
The West
Looks like they had a lot of trouble getting it to work in some of their test boards though. I'd be nervous about using an 800Mhz FSB chip with it too. Seem's like most people would be better off just paying $100 for a new motherboard, unless they're really desperate to keep their 845E boards in use.
Cowboy X
Cowboy X
Folding in Barbados
That is the problem with most powerleap adaptors especially the tualatin ones because their price is often on par with a new board . But in this case the difference is only $20 . As the review said if you can get it from a place with a return policy or Powerleap themselves you can't go wrong . If it works ....... hooray ............ if it doesn't , send it back .
JCLW
So how long before someone buys it and figures out how they did it? Then maybe everyone could just do pin mods. I might be tempted to do it if I had a P4 system, but all my setups are P6 based :rolleyes:.
- JW
JCLW
Pentium core was P5
Pentium Pro, PII, and PIII cores are P6
Original P4 core was going to be codenamed P7 but they changed it so the P4 is just known as the P4.
So in order it went ... 8088, 8086, 286, 386, 486, P5, P6, P4.
- JW
JaY_III
Senior of BX
JCLW said:
Pentium core was P5
- JW
actually the P4 core is the P68
the Itanium is the P7 :D
hoytron
Duluth, MN
I'm a bit unclear about exactly what this adapter does. It claims to offer hyper-threading in non-hyperthreading boards, but requires the ability to select hyperthreading in your BIOS. If you can turn on hyperthreading in your mobos BIOS already, where's the issue?
