- Jul 7, 2013
I use microsoft security essentials for my anti-virus, it's free and seems to get the job done. well, until now that is. in AppData/Roaming/ there is a hidden folder that is labeled System32.ini and in it is a single exe file, WinLogon. the security window that asks if you want to run a program keeps popping up for WinLogon from System32.ini. i assumed it was the service that allows you to log on but i was suspicious, so i checked task manager and winlogon.exe was running according to what i saw. AND just now after another window popped up asking if i wanted to run the program, some sort of installer popped up.i quickly closed both out and scanned the folder with security essentials, but nothing came up. my question is, is it a virus and if security essentials can't detect it how do i get rid of it? also, is it safe to delete this System32.ini folder? it isn't the System32 in the Windows folder, but i did have to choose to show important operating system files and folders to get the .ini folder to show up. if anyone could try and shed some light on the situation i'd appreciate it!
