I just re-applied my HSF to my little Athy Xp 1800+ with some newer AC3, I was reading that after you freshly install the HSF that you should torture test (full load) the CPU right away? Is this correct?
I went ahead and started it right after the applying, and its running rock stable even as its running right now and im typing this, hehe. I will tell you one thing, it is very hard to cool a CPU in Las Vegas where the ambient temps are much higher then everywhere else in the country! Still, at FULL LOAD with Prime 95 im hitting 44c. I idle around 36c.
Question #2, how long do I run Prime after installing the HSF for it to cure properly? Thanks in advance!
Cheers.
Cheers.
