my build
asus z170-ar
i5 6600k (OC to 4.5ghz at 1.255 Volts) EDIT(while running prime 95 CPUZ had my volts at 1.264v)
33c idle the cores are around 60c no higher under-load
8gb ddr4 2400
gtx 1070 g1
850W ax PSU
the only thing i changed in my bios was the voltage and the core ratio nothing else
i'm running prime 95 for about 10 mins it kept saying pass pass pass on all the cores
assuming that's what the 4 windows inside the big window means
i open up the local file it says hardware FAILURE open stress.txt for more information
LOL it says ask yall
i'm using MSI afterburner to monitor everything
and i noticed that one of my core temps was 40c when the other ones were around 49c and higher. i scroll down just a tad bit more and i noticed the core is only working about 48%
i'm assuming that's my hardware failure....
do i need to increase my volts to my CPU to get that core back up OR DID i BLOW OUT A CORE
asus z170-ar
8gb ddr4 2400
gtx 1070 g1
850W ax PSU
